What to look for/avoid...
Old Apr 11, 2006 | 01:20 PM
midlifecrisis's Avatar
Default What to look for/avoid...
Hi all, I'm not a vette owner, but i wanna be. I'm asking for info. In my search for a C5, what do I need to know about the C5? What do I need to avoid? What's troublesome? What do I look for in a used C5? Any and all info will be appreciated. Thanks...
Old Apr 11, 2006 | 05:31 PM
Dave01's Avatar
Default RE: What to look for/avoid...
You might to review this thread:
https://www.corvetteforums.com/m_4838/tm.htm
Good luck!
Old Apr 17, 2006 | 12:24 PM
Thanks, DAVE01...
anybody else have any info/opinions????
Old Apr 17, 2006 | 02:48 PM
Team 4R's Avatar
upon a cursory glance, i didn't see the leaking battery acid issue mentioned in that link....
to me, that is the single biggest deciding factor on a car that, overall, looks pretty good... you'll have to pull the battery and check under/behind it for acid corrosion. if it's there, it will lead to bigger and better problems, especially electrical. if it's not there, go ahead and buy the car, but switch to a gel-type battery soon (optima red top seems a popular choice).
beyond that, these cars aren't OLD yet, but the earlier ones are getting up in age... pay a little more and get a newer one with low mileage, and it should save you maintenance costs in the short term.
edit: or get an older one and overhaul the engine so it's essentially new.... ahh, decisions.
Old Apr 20, 2006 | 02:56 PM
chgofd44's Avatar
Make sure you get one with the column lock replaced. That is the only thing that has ever went wrong with my C5. You will love the car!!
Old Apr 20, 2006 | 06:39 PM
The leaking battery thing is not particularly common to or special on 'vettes: it's rare but happens on any car, sometimes due to a ba aalternator controller. Regardless, on an M6 check the 2nd and 3rd gear synchros, and the rack and pinion for leaks.
Old Apr 20, 2006 | 07:37 PM
Dave01's Avatar
ORIGINAL: Team 4R
I guess I didn't mention it because
a) 2001-2004s came with leakproof AGM batteries and
b) Most pre-2001 C5s have replacement batteries in them already
I plan on getting an Exide Orbital battery when my OEM battery bites the dust.
Old Apr 21, 2006 | 12:13 AM
A lot of times a "leaky battery" can be caused by alternator overcharging. Check your voltage and amperage readings (charging). [8D]
corvette king
Mar 16, 2006 07:59 PM
Danase
Jan 13, 2006 01:00 PM
bRKrbcing
Sep 15, 2005 02:44 AM
adelii
Jun 28, 2005 02:51 AM
