WHIPER PROBLEM
Old Jun 12, 2007 | 06:01 PM
hidking's Avatar
Default WHIPER PROBLEM
alright guys i have a 99 vette... just today.... it was raining yesterday and i left the switch to the wiper blades on... so i start up my car today and shut them right to the off position... all of a sudden the wipers went on by them selves... then off... then back on and stayed stuck in one position for a few min then back down and back on... well you guys get the idea... what in the world is going on with them?
Old Jun 12, 2007 | 07:26 PM
extanker's Avatar
Default RE: WHIPER PROBLEM
check your utters they may be clogged with junk,then the motor may dry out
Old Jun 12, 2007 | 08:34 PM
hidking's Avatar
what are utters?
Old Jun 12, 2007 | 08:58 PM
hidking's Avatar
also is there a way to fix this without replacing the wiper motors?
Old Jun 15, 2007 | 11:35 PM
extanker's Avatar
they are rubber drains under the wiper motor and they clog up.the motor may dry out but not if the cowl is filled with water
Old Jun 16, 2007 | 08:37 AM
hidking's Avatar
i cleaned those drains out and the damn things still wont shut off (cleaned them out a few days ago)... now today i just sprayed down the wiper motor to make sure nothing was clogging it... how the hell am i supposed to fix this anyone know?
Old Jun 16, 2007 | 01:49 PM
extanker's Avatar
ya didnt say if they had crud in them.the wiper motor module may have water in it.you will have to remove assembly and dry out.i poured a shot glass of alcohol in module,sloshed it around [twice] then put in front of a fan for a day.the module it bolted to the motor on the bottom.DO NOT remove the large torx bolt that holds arm to motor ifd ya do and mess up the timing the wipers will try to wipe your hood.test tree calls for undoing stalk switch elect. conn. and if it still occurs the stalk switch is ok
Old Jun 16, 2007 | 06:35 PM
hidking's Avatar
hey could you tell me where the whiper fuse is? im gonna pull it untill i get this problem fixed
Old Jun 16, 2007 | 08:55 PM
extanker's Avatar
passenger side foot panel
reactor2
Sep 4, 2006 09:33 PM
