Corvette C6 Forum 2005+
difficult engine cranking
Old Aug 23, 2022 | 07:36 PM
jetmech09's Avatar
Question difficult engine cranking
i am having an issue starting the engine , acts like a week battery very slow to turn the engine over . it will crank very very slow then get up to speed till engine starts . battery was tested good, I have a msd mini starter with a thermal blanket to protect from header heat . i have replaced the battery terminals .car does this even when its been sitting over night. need ideas on what to look for before I buy a new starter
Old Aug 24, 2022 | 09:42 AM
It sounds like your battery cables are not up to par. Weak cables or maybe bad grounds, ground from battery to frame, then frame to the engine block are a must have. A good + Cable battery to starter. Before changing the starter I would try using jumper cables along with the battery in the car and cables you have, and attach the jumper cables directly to the starter and see if that makes a difference. then after that try jumpers on the existing battery and see if that makes a difference. I don`t think it`s the starter.(I have been wrong sometimes) But it can be a loose connection in the starter heating up and making contact, or (maybe) Bad contact on or inside the solenoid could do the same thing. That`s all I got.. Good luck on your hunt!
Old Aug 25, 2022 | 12:08 PM
Timing and compression ratio can put a heavy load on a starter.
Is this something that just happened or did it happen when the mini starter was installed?
ShckByte
Aug 24, 2021 10:47 AM
LT4Dave
Mar 22, 2008 11:45 AM
blueshark
Aug 24, 2007 05:53 AM
red90vettesc
Dec 31, 2006 12:29 AM
Phantom
Dec 31, 2005 08:09 PM
