Corvette C6 Forum 2005+
Tire Pressure
Old Jul 26, 2007 | 11:37 AM
Patrick004's Avatar
Default Tire Pressure
Hello all. Just a quick question related to the optimal cold/hot tire pressure on these F1's. Is there a consensus on the best pressure to run these for both performance and longevity?(not that they will lat very long at the rate I am going)
Old Jul 26, 2007 | 09:39 PM
chargedvette02's Avatar
Default RE: Tire Pressure
I run my bfg's at 32 psi.
Old Jul 27, 2007 | 06:06 PM
I ran my stock F1s at 33-34 lbs on both ends and had fairly even tire wear.
A rule of thumb on upgraded tires is to run tire pressures inversely proportional to section width: for example at the rear I'm running 345s instead of stock 295s, so I set the rears at 295/345 x 33lbs =28 lbs on the street. At the track, since they are drag radials, I reduce pressure to 24 lbs to get a bit more bite.
bobvet
Jan 19, 2007 02:59 PM
2001c5
Nov 29, 2006 08:42 PM
rjensen
Jun 26, 2006 09:17 PM
sorlowski
Dec 4, 2005 11:01 AM
bRKrbcing
Jun 29, 2005 03:25 AM
