Corvette C6 Forum 2005+
Water seperator/pcv
Old Jul 22, 2014 | 11:48 AM
16monkies's Avatar
Default Water seperator/pcv
I determined that my PO 171 and 174 trouble codes on my '09 LS3 were do to a vacuum leak. I found a water separator in front of the PCV valve (my guess is that it was installed to eliminate blow-by.) At any rate, the water separator was damaged and caused a vacuum leak. I removed it, at least temporarily, to stop the vacuum leak and smooth out the engine, which it did. The air/fuel ratio is now spot on. How necessary is the separator?
Thanks for your insight and suggestions.
Old Jul 23, 2014 | 09:18 AM
Is the water separator stock or did someone add it as an aftermarket device?
Old Jul 23, 2014 | 03:33 PM
16monkies's Avatar
Hi,
It was installed after market when the engine was tuned with a twin turbo system. I was able to locate a replacement from Norgren. In the mean time, the by pass is working fine.
Old Jul 23, 2014 | 08:11 PM
What's it separating the water from? Water injection maybe?
Does it still have the twin turbos?
Old Jul 24, 2014 | 03:55 PM
16monkies's Avatar
I'm no wrench but anything that breathes creates condensation. This separator expels the condensation prior to entering the crankcase. Yes, the turbos are intact.
Old Jul 24, 2014 | 09:46 PM
On a normally aspirated engine, the condensation is disposed of thru the PCV and burned.
Old Jul 25, 2014 | 07:30 AM
16monkies's Avatar
Perhaps the turbos cause more condensation than the crankcase can otherwise handle.
Old Jul 25, 2014 | 08:37 PM
Could be but I'd need somebody to explain the physics to me.
2001c5
Feb 2, 2007 05:49 PM
jmtrotzie
Oct 8, 2006 10:18 PM
dcd58
Nov 10, 2005 08:49 PM
farhan
Oct 7, 2005 02:54 PM
tshirttom
May 11, 2005 09:54 PM
