Z06 Exhaust Butterfly settings...
Old Jul 5, 2007 | 03:38 PM
steve611's Avatar
Default Z06 Exhaust Butterfly settings...
I've had my 2007Z06 for just over a month now, awesome car!... someone told me the exhaust butterfly values you see at the rear of the exhaust systemare closed for normal operation and open when you get on the accelerator... my questions are; Is this true?... my observation is they are always open. Comments?
Thanks... Steve
Old Jul 5, 2007 | 04:05 PM
Default RE: Z06 Exhaust Butterfly settings...
What you were told is true, during normal driving the butterfly valves are closed and they open only under certain conditions of higher RPM and full throttle, etc. They are closed at idle and when the car is at rest, etc.
Check whether: a) what you are looking at is in fact the butterfly valve, and b) that it is closed when the car is stationary but the engine is idling. I have what is basically the same type of system on my Porsche and the valves stay open when the engine is off,but shut as soon as it is started and at idle. May be the 'vette is similar, I've never bothered to look.
Old Jul 9, 2007 | 01:07 PM
steve611's Avatar
Thanks Lee for the tip... this weekend I checked the exhaust butterfly values and you are right, they close once the engine is started and at idle (and completely open when engine of off).
dan2002z06
Sep 25, 2007 06:39 PM
z06_23_45
May 14, 2007 07:11 PM
mutheta46
Nov 1, 2006 05:25 PM
nautques4ever
May 17, 2006 09:11 PM
csteege
Oct 11, 2005 01:58 PM
