Heads up Display (HUD) Question
The HUD in my 2016 ZO6 is working fine. All the data is there, and it scrolls through the various screens with no problem. So what's the beef ?
When I first got the car two years ago, the HUD automatically displayed the RPM, G force etc. I had the battery changed. Now on startup all I get is the car speed and speed limit. No biggie, I just scroll to the display I want and we're good. Not a major problem but its slightly irksome having to do it every time I start up.
Where do I find the setting to keep the HUD on a particular screen at startup ?
Thanks
Thanks
Welcome to the forums. Sounds like it needs a reset, have you researched Google? Check other Corvette forums and see what pops up. Its helps sometimes to connect a 9 volt battery into the cars 12 volt power source to prevent that from happening when replacing the battery. I will do some checking and see what I can find out. You can check with the independent repair shops in your area and see if they have an answer, I'm sure this issue comes up sometimes with all the electronics these days.
