CA SMOG Check
I took my new2024 C8 for a smog check here in CA. The guy hooked up a code reader and it showed 4 different areas that did not have a green checkmark next to it. He told me that the car would not pass a smog check at that time. He told me to go put more miles on the car. (I only had about 85 miles on the car). I put a few more hundred miles on it and ow two areas are ot checked greed. Then I stated hearing the GM will not let the Oxygen seńsor?? & Cat. Converter?? be able to operate correctly?? until about 1,200 miles have been put on the car. And I have to have that done within the 20 days the DMV gives me to register the car here in CA. I should reach that distance tomorrow so I am excited to see if the two areas that are not checked on the code reader will then be checked when I reach the 1,200 miles.
I also took the car to a Chevrolet Dealer Service department and they said they will not do a smog check until 1,200 miles are on the car as well. Anyone else have this problem? Cross your fingers that I can get it to pass the SMOG Check.
I am adding another update on the "O" sensor on the code reader I am using to see when I can take the vehicle in for a smog check. I now have approx. 1,350 miles and the "O" sensor still has not got a green check mark next to it. All other diagnostics are green and good to go. Anybody have that problem?
Everybody that sees it say they like the color yet it's only about a 4% take. I think part of that is due to the fact if you only see it on a computer, you will see a distinct green cast to it. I know I had to see it in person before I put it on the order blank.
Very interesting, My first impression was mellow yellow with a touch of green. It's a bright happy color. I wore bright green T shirts at work in construction for years so I got used to the bright green's, but your car is a big step down from that. I like it. Good choice.
aeronos
Dec 14, 2006 02:51 PM
