Corvette Forums Help & Suggestion Center Need help with Corvette Forums? Ask. Have a suggestion to better CF? Tell us here.
99 headlight mechanism
Old Aug 3, 2011 | 09:37 PM
oborski2's Avatar
Default 99 headlight mechanism
i HAVE A 99 VETTE WITH A PROBLEM HEADLIGHT. i NEED THE MECHANISM (MOTOR) THAT OPERATES IT. WHEN i TURN THEM ON THE DRIVERS SIDE WORKS FINE BUT THE PASSENGER SIDE DOESN'T OPEN ALL THE WAY. WHERE CAN I GET THIS MECHANISM? THANK YOU.
Old Aug 7, 2011 | 12:54 AM
Try www.ecklers.com. You're opening gears are made of plastic from the factory. Before you order the whole mechanism have a look at the gear. If the teeth are overly worn or missing than that is most likely your problem. You can also get brass replacements from what I understand. There's also the fix of after market fixed headlights. You may also want to have a look at your vacuum lines. They tend to dry out, get brittle and crack from the excessive heat in the engine bay. Trace them back to the reservoir. Keep us posted and post some pictures of your vette. We love pictures around here.
Cheers
capcollett
Oct 16, 2006 11:17 AM
rjensen
Sep 8, 2006 01:37 AM
jdavis
Sep 3, 2005 11:29 PM
Dans endless project
Aug 17, 2005 04:49 PM
Aug 16, 2005 03:09 PM
