1965 Hood Stuck
Old Sep 21, 2007 | 07:15 PM
1965corvette's Avatar
Default 1965 Hood Stuck
My Hood latch cable has broken on the right side. When I pull the hood release handle the left side will open, but not the right. Is there a way to manually open the right side.
Old Sep 21, 2007 | 09:20 PM
pg's Avatar
Default RE: 1965 Hood Stuck
Hi 1965 corvette owner, welcometo the forum. On myC-3 there is a cable that runs from the left to the right side, Not sure if the C-2 is the same but if you can lift one side enough to pull that cable towards the back of the car that might do it. Hope that helps, PG.
Old Sep 21, 2007 | 11:11 PM
Thank you. I will try it.
Old Sep 28, 2007 | 07:38 AM
scottr65's Avatar
If that did not work, I think you may be able to get at the latch from underneath. I posted a response with a picto you over in the C1 & C2 section at
https://www.corvetteforums.com/m_43181/tm.htm
73shark
Nov 15, 2007 10:39 PM
1965corvette
Sep 26, 2007 10:17 PM
fille9
Sep 17, 2006 06:50 PM
steve47714
May 18, 2006 02:29 AM
dave n
Jul 5, 2005 12:22 PM
