1974, L-82 convert
Old Jun 17, 2007 | 08:11 AM
Bill C's Avatar
Default 1974, L-82 convert
I would like some feedback on security devices for a '74 convert L-82.
Years ago I setup a switch between the condensor and coil of my Datsun 280Z that worked well. The L-82 has been converted to electronic ignition, so this is not possible, but is there a wire or circuit that would lend itself to this ?
Any other ideas on convertible security ?
BC
Old Jun 17, 2007 | 01:18 PM
78buckshot's Avatar
Default RE: 1974, L-82 convert
With a GM HEI distributor you can dissable the ignition by breaking the main battery power going into the ignition system or by breaking the the trigger wire comming back from the pickup coil to the ignition coil. If your running an aftermarket ignition I would think there would be a similar circuit you can break with a switch.
Old Jun 17, 2007 | 04:45 PM
I've done simular, only went under dash and put a switch where the wire goes from the bat to the ignition switch.
06 Vette
Jul 15, 2006 11:43 AM
nautques4ever
Jun 19, 2006 10:28 PM
vettenet
Dec 7, 2005 03:21 AM
ram99vette
Nov 8, 2005 08:24 PM
rtchevrolet
Aug 14, 2005 06:57 PM
