65 directional switch
Old Oct 25, 2007 | 08:12 PM
duncanr001's Avatar
Default 65 directional switch
A friend has a 1965 corvette. Both tail lights blink when the ignition is turned on. They both stay on if the brake pedal is pressed. He just went through the long procedure of disassembling the steering column and replacing the directional switch with a NEW one. He has owned and worked on his 3 corvettes for years. Wiring diagrams do not show how switch actually works. Any help appreciated.
Old Oct 25, 2007 | 08:45 PM
Default RE: 65 directional switch
Up is right, down is left.
I'm sorry, I couldn't help it. [&o]
Maybe, now just maybe, the emergency flasher is activated. Check it, it's so easy toturn it onand not know it, especially when working around the steering colume.
Old Oct 26, 2007 | 12:45 PM
duncanr001's Avatar
This 65 (and I believe all) do not have emergency flashers. But thanks for the fast response. We believe the brand new switch had the same defect as the old one we removed. We connected another switch (not installed, just plugged in) and all appears fine. We are about to replace the switch (dissassemble the steering column) once again. We're goin to check for cross shorts or grounds we may have caused during the initial installation of the new switch by trying it plugged but uninstall in the column. What a bear of a job.
Old Nov 6, 2007 | 04:19 PM
duncanr001's Avatar
Replaced switch with new one and all is well. Last NEW switch was defective.
Redwhisper
Jun 25, 2011 06:09 PM
duncanr001
Technical Diagram Help
Oct 25, 2007 08:04 PM
TripleBlackC5
Oct 15, 2007 07:14 PM
keverson
Nov 4, 2005 09:26 PM
jotto
Oct 27, 2005 08:56 PM
