74 350 with Rough Idle
Old May 2, 2010 | 10:36 PM
  #11
partsman41's Avatar
To each his own,I guess? I have had nothing but problems trying to use Autolites or Champions in my Chevys,never had troubles with the AC's As far as the plugs from that other country,I use lots of them in my bikes,but they either come from,or were designed by the folks in the other country.
OK,I'm ducking!
Yes,you are lucky! Noises from the back of the motor almost never turn out well.
Ron
Old May 2, 2010 | 10:58 PM
  #12
Glad it worked out so well for ya Schoon, yes, I'll go to my room now.
Old May 3, 2010 | 07:14 PM
  #13
SCHOON's Avatar
Hey guys,
I really appreciate your input.
You saved my a** a few times over the years.
I really thought my engine was toast this time.
Schoon
Old May 7, 2010 | 05:20 PM
  #14
SCHOON's Avatar
My Vet is cursed!
Got it back and it was running fine.
All of a sudden the rattle came back stronger then ever.
So now I know it is not the clutch fan or the plugs.
It doesn't start untill you drive around awhile and the engine warms up real good.
Now I am thinking it's my clutch.
Stayed tunned.
Schoon
Old May 9, 2010 | 09:25 PM
  #15
Schoon,
Does the noise change if you depress your clutch? Could be throwout bearing.
Old May 10, 2010 | 06:47 PM
  #16
SCHOON's Avatar
No change in the noise if I push the clutch in or put the trans in neutral.
Noise changes if the RPM goes up.
Going to take off the dust cover on the bell housing to look around.
I might have a bad flywheel or toasted clutch, who knows?
Stay tuned.
Schoon
Old May 13, 2010 | 04:58 PM
  #17
Shadowtrap's Avatar
A good piece of vacuum hose or a screw driver can make a quick stethoscope.
acossey
Oct 4, 2019 01:25 PM
proto69
Nov 9, 2006 03:18 PM
wandlwilliams
Oct 4, 2006 08:03 AM
gearhaed
Oct 4, 2006 07:55 AM
90fredvette
Jun 15, 2006 01:01 AM
