air flow
Old Mar 3, 2007 | 10:41 PM
repodude43's Avatar
Default air flow
took the top ot of my air cleaner to give more airflo seemed to help off the line and didnt spend 50.00 for a frame that was already cut. ill let yall know how it helps
Old Mar 5, 2007 | 11:38 PM
repodude43's Avatar
Default RE: air flow
well i see that yall stop in to look but no responce well i took it out for a ride i think that this helped my car more than anything ive done so far [sm=happybounce.gif]
Old Mar 6, 2007 | 12:29 PM
Kimber's Avatar
I've been told that running with the air cleaner open (top off) can cause a serious risk of fire? Something about causing backfires or if a backfire were to occur?
Old Mar 6, 2007 | 06:55 PM
Black86vette's Avatar
Why not cut the lid open yourself.......................
Old Mar 8, 2007 | 06:36 PM
repodude43's Avatar
thats what ive done i cut the centermetal part out left the plastic cover on it gave me about three times more opening
Old Mar 8, 2007 | 07:47 PM
Well if it works for you fine but:
a) it's hard to understand why it would work better than stock, much less a good cold air induction system none of which produce a terribly obvious seat of the pants power increase without tuning, etc.
b) I would love to see a before and after dyno result to confirm the result to see where and why the power change is produced and what this "mod" does to A/F ratio
Old Mar 9, 2007 | 07:56 PM
K&N and a cutlid= ten horsepower from "supposed" dyno results. You can check out some other forums and type it in the search forum...Digital corvettes or something....It will show up some results. I have read it before. Fire? I dont think so. If hes talking about the air cleaner lid, no risk of fire.....It is opening up and showing the full surface area of the filter....I would think that the fire would start from leaves being stuck in the STOCK one that is not cut open....Which I highly.....highly doubt....
iresolver
Sep 8, 2007 10:10 PM
mypetu39
Jul 5, 2007 03:48 PM
liviz40102
Aug 14, 2006 04:20 AM
kvette
Oct 24, 2005 01:16 PM
PAULKR
Sep 11, 2005 05:49 PM
