constant 130 psi oil reading
Old Mar 12, 2007 | 09:08 PM
DAYUIZ's Avatar
Default constant 130 psi oil reading
Even when the engine is cold and the ignition is turned to on without starting the car the display reads 128-130 psi and the oil dial gauge reads maxed out at 80psi. The car drives and idles normal but the gauge reading never changes. Always reads 128-130 psi. I'm thinking it's a guage malfunction or some sort of grounding issue. The dealership said their going to look at it but I'd like your opinions.
Thanks,
Steve
Old Mar 12, 2007 | 11:07 PM
extanker's Avatar
Default RE: constant 130 psi oil reading
its the sending unit.if you fix it DONOT buy oem unit.it will fail again
Old Mar 13, 2007 | 12:59 PM
riley's Avatar
Yes, it is almost certainly the sending unit. If you are talking about a C5, the sending unit is on top of the engine near the firewall. You have to remove the intake manifold to change it. I read something awhile back about cutting a hole in the plastic above it.
Like extanker said, do some research on a replacement unit. Some guys have had the dealer replace it and had it fail on the way home from the dealer.
It's a pretty common failure and you should be able to google up some info on it.
Old Mar 17, 2007 | 04:44 PM
DAYUIZ's Avatar
Thats good news. I thought it was probably a bad sending unit. What aftermarket sending unit do you guys recommend?
I'm not sure if I want to tear into the engine just yet. Knowing my it'll start with replaceing the oil pressure sending unit, and finish with a header/cam install.
-Steve
Old Mar 17, 2007 | 05:36 PM
extanker's Avatar
anyone except oem
SpeedyKev64
May 25, 2014 10:34 PM
1red93
Jan 23, 2008 07:07 PM
SperasC3
Oct 26, 2006 03:50 PM
LMan
May 6, 2006 05:28 PM
HillSmith
Sep 6, 2005 11:53 PM
