head-Lt. cover not opening
Old Dec 15, 2005 | 01:25 PM
Texas Jim's Avatar
Default head-Lt. cover not opening
My driver side head light cover isn't opening. I find no bad or disconnected vacuum lines and am wondering if the actuator or relay valve could be the problem, as I am losing vacuum when I pull the light switch. The GM shop manual doesn't cover trouble-shooting the head light assembly. Does anyone know how to find the root of my problem??? Thanks in advance.
Old Nov 17, 2006 | 09:04 PM
repodude43's Avatar
Default RE: head-Lt. cover not opening
gear in headlite motor bad you can buy a kit at part store if they dont have for vette get a window motor repair kit for fords its the same thing good luck johnny
Old Nov 17, 2006 | 09:05 PM
repodude43's Avatar
hey sorry you have vac not eletric ill stut up and go back to sleep
Old Nov 17, 2006 | 09:13 PM
You might try this....
with the engine running, and the light switch on, go in steps, disconnecting the vaccuume lines for that light. start at that light. When you find vaccuume, what ever follows in line is bad.
beefcake
Feb 6, 2008 10:39 PM
Curious George
Dec 9, 2007 06:21 AM
yaj15
Nov 6, 2007 06:41 AM
dazed_n_confuzd
Aug 17, 2007 05:44 PM
drbill
Corvette C6 Z06
Jul 23, 2007 03:19 PM
