HELP WITH TIMING
Old Mar 22, 2007 | 01:35 AM
repodude43's Avatar
Default HELP WITH TIMING
I have 93 with msd optispark want to know what degree of timing would be best for performance would like any help
Old Mar 22, 2007 | 01:38 AM
Default RE: HELP WITH TIMING
Old school teachings tell me, depending on elevation, 5 to 7 degrees.
Old Mar 22, 2007 | 08:41 AM
extanker's Avatar
if ya got the "tuneup specs sticker" under hood use that as a base then advance till ping then back off 2 degrees
Old Mar 22, 2007 | 09:19 AM
Timing is ECM controlled on Optispark from the factory, not sure about MSD.
Old Mar 22, 2007 | 09:53 AM
ORIGINAL: mech259
That's what I was afraid of...
This 'puter controled stuff really leaves me in the dark a lot of times.
Sorry I couldn't have been more help.[&o]
Old Mar 22, 2007 | 11:45 PM
extanker's Avatar
maybe i misunderstood with the msd. does it have a stand alone msd box [controller] it may have rotary switchs for adjusting timing
Old Mar 24, 2007 | 01:00 PM
repodude43's Avatar
the msd optispark has a set screw that lets you adjust timing afew deg i have not messed with it yet wanted input first
Old Mar 24, 2007 | 01:06 PM
repodude43's Avatar
http://www.msdignition.com/2006/06-4.htm this is what i have
Old Mar 24, 2007 | 05:06 PM
extanker's Avatar
okeedokee .a few ways to play with the timing. first check it with a t light and mark it down so you know where your base is. follow the how to on timing and advance it 2 degrees then road test it. most important is no "ping or knock" .come back and advance it all the way [it has 5 degrees max if that is your system] road test again .ya want no ping or knock. if ya get it back off [retard] 2 degrees. with a max of 5 degrees i doubt ya will hurt anything
diojr
Aug 6, 2007 03:39 PM
repodude43
Mar 19, 2007 01:11 PM
lrod
Dec 23, 2006 07:20 PM
josephgts
Feb 8, 2006 11:47 AM
jess_p
Nov 15, 2005 01:19 PM
