No Fuel
Old Mar 17, 2010 | 09:01 AM
WBHJRGFH's Avatar
Default No Fuel
I have an electric problem some place in the fuel systems.
Old Mar 30, 2010 | 10:52 PM
Need more info, no fuel, and......?
Did ya check these?
Blown fuse?
Clogged filter?
Bad pump?
Burnt wires?
injectors elec./clogged?
Ya see, We need ya to help narrow it down.
Old Apr 26, 2010 | 09:12 AM
chrish4161's Avatar
Oh man that is really a dangerous for you. The fuel system is the risky part of the car and you have some electrical wiring problem over there. I would suggest to clear you fuel from tank and then try to check it where is the problem. First of all check the spark plug connection wiring through the main connection of the battery.
Old Apr 26, 2010 | 06:08 PM
Ah-hem, are you suggesting to drain the fuel tank?
Bad Idea, an empty tank is just as dangerous, if not more, than a full one.
That tank full of fumes is a lot more explosive than a full tank.
The elec system that is related to the fuel system is well protected.
The "No fuel" problem has nothing to do with the spark plugs, or the battery.
Sheesh,.....
slayerz06
Feb 10, 2009 10:48 PM
