No Fuel
Oh man that is really a dangerous for you. The fuel system is the risky part of the car and you have some electrical wiring problem over there. I would suggest to clear you fuel from tank and then try to check it where is the problem. First of all check the spark plug connection wiring through the main connection of the battery.
Bad Idea, an empty tank is just as dangerous, if not more, than a full one.
That tank full of fumes is a lot more explosive than a full tank.
The elec system that is related to the fuel system is well protected.
The "No fuel" problem has nothing to do with the spark plugs, or the battery.
Sheesh,.....
