tach
Old Feb 17, 2008 | 06:43 PM
mytoy's Avatar
Default tach
i have a 78 L82 four speed, when the car is running the tach works fine when it is turned off the tach stays around 1000 , any help would be appreciated thanks mytoy
Old Feb 27, 2008 | 04:10 PM
moscooter's Avatar
Default RE: tach
I guess you have never owned a boat with a tach on it. It is a "common" thing for a tach (with the switch off) to NOT return to zero..........such as a speedometer.
You say it's working OK when the car is running!? Why should you get concerned where the needle is, when the car is just sitting there, engine off????????????????????????????????????
Old Feb 27, 2008 | 05:25 PM
78buckshot's Avatar
Default RE: tach
Hi mytoy, welcome to the site. The tach on your year is an electronic unit that gets a signal from the HEI distributor when running, when you shut it down the tach will not normally go to zero, after the engine stops turn the key back to the run position, the tach should then rest at zero RPM, when you turn the key to off the tach will again find an irrelevant resting spot, this is normal operation.
91flawless6spd
Oct 18, 2006 07:14 PM
P
Sep 22, 2006 05:01 PM
SCHOON
Sep 14, 2006 02:00 PM
P
Aug 24, 2006 09:48 AM
toml14
Mar 23, 2006 08:41 PM
