wonderbar radio
Hey guys, I am trying to get my radio working. It's a 61 hybrid and I have repaired a few cold solder joints, the power transister, a broken wire and still nothing. I am down to needing a schematic. I am not even shure the tubes are in the correct spots. Any help out there with maybe a copy of a Sams Photofact or something so I can get this thing going? Thanks, Bruce.
I have repaired a few of those! I do not have any schematics, but you may want to check the vibrator and the capacitors. Those old paper caps were / are notorious for leaking. There should be a diagram of what tube goes where unless it fell off the chassis long ago.
CG
CG
Thanks George,
The radio is one of those hybrids so there is no vibrator and I thought
there should have been a tube layout but it is long gone. I am sure the glue
dried and the diagram fell off. I will take a close look at the caps though.
Sure would help if I had a schematic so I could check some voltages. Thanks
again, Bruce.
again, Bruce.
deansreef
Mar 23, 2007 11:56 PM
