Kangen Water
Old Feb 27, 2012 | 02:00 AM
jonsonharrises's Avatar
From: Life Ionizers, 6352 Corte Del Abeto, Sute H.Carlsbad, CA 92011
Default Kangen Water
Enagic water ionizers require cleaning after being used to make strong acidic water. The machine must run a cleaning cycle, and then owners should run water through their machine and allow it to flush itself. The chemical used to make strong acid water is called Sodium Hypochlorite. Enagic® calls their additive chemical an “electrolysis enhancer”
The problem with Sodium Hypochlorite is that it breaks down to sodium and hypochlorous acid – commonly known as bleach! – When electrolyzed. Hypochlorous acid bleach is a weak acid, but over time, it can oxidize platinum and cause it to be stripped from the Enagic® machine’s plates.
vwygonik
Feb 14, 2006 03:37 PM
dcd58
Nov 12, 2005 09:22 AM
dcd58
Nov 10, 2005 08:49 PM
farhan
Oct 7, 2005 02:54 PM
tshirttom
May 11, 2005 09:54 PM
