Mild 2 Wild
does getting one of these do anything adverse to the vehicle? I know it makes it sound differnt, but I do not want to harm the vehicle in any way. Also, if you have installed one, are you happy with it, and does it fit into the fuse box ? Finally, I note in the instructions (on line) that there is a different method to install with zero battery drain, has anybody done that?
One of what? I see nothing that indicates what device you are talking about. There are dozens of products named Mild to Wild, including, of all things, some sort of pepper-based seasoning for food, and lots for cars.
If you are talking about the exhaust cutout override switch marketed by Mild to Wild, I doubt it would hurt anything, but you can rig the same thing yourself if you know how, that device just saves time particularly if you don't know wiring well. But regardless, it won't hurt the car, just mean you make a lot more noise at lower RPM, and it may also cut your low end torque -- when I do the same thing to my Aston I lose about 10 lbs of end torque below 4000 RPM.
