Revolutionary set of XB DRL Bar Projector LED Headlights by Morimoto Under Review
Some cars may require a lot of modifications to be noticed, while the others, like your C6 Chevy Corvette, require just a couple of personalization touches to be in the spotlight wherever you go. The team at Morimoto has recently come up with an absolutely revolutionary set of custom headlights manufactured to provide you with more lighting power, enhance your road safety and help you to set your Corvette apart from the rest.
Consider buying our XB Black DRL Bar Projector LED Headlights with Sequential Turn Signal by Morimoto if you're looking for a reliable LED powered headlamps that feature a beautiful, one of a kind design and perform equally well, day or night. Morimoto XB Headlights are powerful enough to outperform most of the alternatives offered on the market nowadays and produce a much more focused and better-aligned beam pattern, which results in excellent road visibility in all weather conditions. It is a sinister looking set of headlights outfitted with wear-resistant lenses and durable housings. Morimoto headlights meet all SAE, DOT, and FMVSS108 regulations, so you're safe to go with it for your daily driver. All hardware required for installation is included in the kit. We bet that the end result will impress you.
Watch our very own product video review, prepared by CARiD Team and our technical expert Greg to find out more details on the outstanding set of XB™ Black DRL Bar Projector LED Headlights by Morimoto:
Notes:
*1 Pair. Black housing, clear lens.
Includes:
* (2) Headlights;
* Flicker/hyperflash modules;
* Plug and play wiring harness;
Outfit your C6 Corvette with a set of Morimoto XB DRL Bar Projector LED Headlights to get excellent visibility and a modern look.
carid
Aug 9, 2018 05:37 AM
