How to install a hypertech thermal chip?
Old 07-21-2007, 07:59 AM
dburke's Avatar
Default How to install a hypertech thermal chip?
Does anyone know howto install Hypertechthemal chip in my '93? OR how to I get the OEM chip out of the ECM?
Thanks,
Dan
Old 07-21-2007, 07:37 PM
LeesVette's Avatar
Default RE: How to install a hypertech thermal chip?
I have a 92 and I installed exactly what you have. You take the ecm cover off and there are two clips that hold the prom in. Undo those and pull the prom out. Make sure you pay attention to the way it goes back in. Plug your Hypertech chip into the prom (piggy back it) and plug the prom back in the way it came out. Fasten the clips, put on the cover and off you go.
Here is a link with the instructions from Hypertech. http://www.hypertech.com/get_install...ion.php?iid=76
You may have to install (and Hypertech recommended I do this) a 160* thermostat also they said that if you don't your fans may run continous and thats not good.
Old 07-22-2007, 01:28 PM
wondering what the part # is for this chip and will it work on a 94? I searched and didnt find one for the 94 all i found was thecompter programmer. Big difference in cost.
Old 07-22-2007, 01:51 PM
LeesVette's Avatar
The same chip that works in the 1992 will work in the 1994. That same chip works in in 1984-1995 cars. As long as its OBDI it will work http://www.hypertech.com/product_searchvehicle.html
Old 07-22-2007, 02:16 PM
Either im blind or something but all i find on that site is the 160degree thermostat. And the power tuner but no chip.
Old 07-24-2007, 01:30 PM
LeesVette's Avatar
Search for the part using the criteria for a 1992.
senorv47
06-06-2016 07:45 PM
23outlaw
08-03-2010 10:38 PM
23outlaw
06-24-2010 11:24 AM
magrag
04-11-2006 11:45 AM
gmbrasco
01-02-2006 10:50 PM
Quick Reply: How to install a hypertech thermal chip?
