Speedometer problems
Old 07-10-2014, 08:28 PM
Larryz's Avatar
Unhappy Speedometer problems
I am trying to fix the speedometer on a 87. The manual states to check E pin on the IP connector for a reading of 10 volts. Where is the IP connector? I believe I have a grounded wire some where as this problem began after I upgraded the transmission. Without a wiring diagram I am having a hard time understanding the circuit between the VSS, ECM, and IP. Any help will be appreciated.
Trimforpay
07-29-2013 12:21 PM
ddc1932
06-02-2007 01:12 AM
ddc1932
06-01-2007 08:23 AM
cadman55
03-10-2007 01:03 AM
liviz40102
01-20-2006 10:04 AM
Quick Reply: Speedometer problems
