82 hood won't open.
Old Jan 21, 2006 | 11:47 PM
GrtAmrTrkr's Avatar
Default 82 hood won't open.
I have a 1982 vette, the hood only releases on the left side, anyone know a way to release the right side latch ?
Old Jan 23, 2006 | 11:29 PM
silver78's Avatar
Default RE: 82 hood won't open.
Do a search for this topic. Someone with the name wifes81 asked the same questions in August 05 and got a good reply with pictures and all.
Here is the address: not sure if it will take you right to it.
https://www.corvetteforums.com/m_133...od/tm.htm#1352
Old Jan 24, 2006 | 12:30 AM
GrtAmrTrkr's Avatar
Thanks Silver 78, that link worked fine. I will take a look at it sometime this week and see if it will work. Time to start getting ready for spring,But can't do much with the hood closed. I take it , by your handle , that you have a Silver 78. Mine is also silver, 82. check my profile, i've posted a picture of it. ( I did'nt find anyone else who posted photos ) Anyway thanks again for the info.
Old Jan 27, 2006 | 11:05 PM
GrtAmrTrkr's Avatar
Thanks to all for the help. the photos posted were not much help, they seem to be from a C1 or a C2. I made a phone call to a near by corvette dealer, who hooked me up with his service manager. He told me to lift up the driver side of the hood far enough to see the left side hood latch,then locate the cable that crosses over to the other side, give it a pull and it should release as long as the cable was not broken off the right latch, if it is i would have a big problem!!! To my relief when i pulled the cable it popped open. To solve future problems with the right side latch, i drilled a hole directly behind the latch release and placed a body plug in it. if it ever happens again i can just remove the plug and pop it open with a screw driver. I replaced the cable and retainer clips and it now works fine.
Thanks again
GrtAmrTrkr
Old Oct 7, 2006 | 11:20 PM
jec327's Avatar
try shooting wd-40 in the latch mechanism. My 1985 vette does the same thing. Pull the release lever kind of swiftly a few times and pull up on the hood at the same time, this works on mine.
9TBLKC4
Aug 28, 2008 09:06 PM
bandojohn
May 16, 2007 12:09 AM
Teddi
Apr 1, 2007 09:09 PM
C3 Starship
Feb 10, 2007 11:11 PM
t1vette
Apr 26, 2006 12:38 AM
