HOOD POPPING OPEN
Old May 14, 2007 | 12:18 PM
bandojohn's Avatar
Default HOOD POPPING OPEN
When I use the hood release on my 1970 the passenger side opens, but I have to manually thump the driver's side to get it to open. However when drivingif I hit even a minor bump the driver's side releases - the passenger side does not.
Anyone have an idea of how to remedy?
Old May 14, 2007 | 03:05 PM
Default RE: HOOD POPPING OPEN
Sounds like the latch needs adjusting. See 1B-2 in the service manual. Basically you can move the catch bolt by loosening the mounting screws, adjust the stop screws with the rubber caps which make the hood align with the fenders, and adjust the height of the catch bolts. Also the catch bolts and the latches on the hood should be lightly lubed.
Old May 14, 2007 | 09:50 PM
Had the same prob. Lubed the latches and cables.
Prob solved.
Old May 14, 2007 | 10:19 PM
pg's Avatar
HI Bandojohn, the hood release on the C-3's will give everyone a problem eventualy, your lucky yours pops open most of the time there stuck closed.
Has anyone put in hood pins? If so, please tell me how to do it. Thanks PG
Old May 15, 2007 | 07:17 PM
Hood pins? On a Vette? Hmmmmm.........they do make a locking type.
Interesting idea pg, I'll hav'ta look inta that'un.
Old May 15, 2007 | 08:35 PM
pg's Avatar
Hi Starship, My hood got stuck closed a long time ago and it took a long while for me to get open.
So then I adjusted the catch bolt and guess what? Still wouldn't open! So after I got it open again I removed the catch bolt and put it in a box with the rest of the spare parts.
So the right latch works and when I need to open the hood I pull up on the lelt side hood up a few inches and reach under the hood and pull the cable that runs left to right under the hood.
So that why I want to go to hood pins. PG
Old May 15, 2007 | 09:01 PM
I understand, like I mentioned, there is a locking type of hood pins. I'm goin' to Summit tomorrow, and will see if they have 'em.
Old May 16, 2007 | 12:09 AM
pg's Avatar
Thanks Starship, any help will be appreciated, auto-zone has the non locking type, and that would be okay for me, I just don't understand how to line them up, like where do you drill the holes and where do you bolt them on where there is enough support. Thanks PG.
9TBLKC4
Aug 28, 2008 09:06 PM
DeepCrush
Nov 13, 2006 01:04 AM
GrtAmrTrkr
Oct 7, 2006 11:20 PM
markcuc
Oct 6, 2006 04:45 PM
daskrizzo
Apr 4, 2006 03:43 AM
