1995 Corvette headlight motor problem
Old 02-17-2006, 10:32 AM
grabie's Avatar
Default 1995 Corvette headlight motor problem
I recently purchased a 1995 (LT1) corvette and have been having problems with the headlight actuators running a couple of seconds after the headlight are up (and down). The sound is like a knock and it happens each time the headlights are turned off or on and even when the parking lights are on. Has anyone had this type of problem and what can be done to correct it? There is no problem with the motors engaging the headlights...only the knocking sound afterwards.
Old 01-22-2007, 09:45 PM
Default RE: 1995 Corvette headlight motor problem
boy it sure sounds like the gears are fixin to go but id get a second opinion.
Old 01-29-2007, 09:03 PM
I have the same problem. Sounds like the teeth on the gears are preventing motor from reaching home position. Too cold to look at mine but I'm sure its not too complicated.
Taffaard
04-30-2009 11:49 AM
vettemanrob
06-01-2008 11:16 PM
vettemanrob
05-30-2006 10:24 PM
grabie
02-17-2006 06:35 PM
jdavis
09-03-2005 11:29 PM
Quick Reply: 1995 Corvette headlight motor problem
