instrument panel lights .. replace 1987
Old Feb 18, 2006 | 03:47 AM
JC's Avatar
JC
Default instrument panel lights .. replace 1987
The right side of my 87 inst panel lights are out,, all guages work fine just cant see them at night.. How much is involved in changing bulbs
Old Feb 26, 2006 | 12:22 AM
crvttbass's Avatar
Default RE: instrument panel lights .. replace 1987
Hi, JC. If you look up at some of the other threads this problem has been addressed pretty well. Good luck with it. And if you do have any questions after reading the other posts just ask again. Someone is sure to help you out.
Old Feb 26, 2006 | 05:30 PM
oldtvman's Avatar
in case you didn't see the other post on display, please check out this link, it is a very good tutorial for repairing most of these problems, http://batee.com/corvette/dcrg/repair.htm. the main problem is the cold solder joints in the power supply module, don't forget to resolder all of these connections, otherwise the problem will continue
larry melton
POLO GREEN 90
Nov 26, 2006 10:37 AM
JC
Feb 23, 2006 08:39 PM
JC
Feb 17, 2006 04:45 PM
Bagpipingjake
Dec 4, 2005 08:50 PM
oldtvman
Jun 1, 2005 07:35 PM
