65 door locks
Old Mar 6, 2006 | 06:40 PM
maberry72's Avatar
Default 65 door locks
I can't lock my doors! It's been this way since I've had the car. I've never had the panels off the doors. What am I getting into? Is this a problem from lack of use?
Old Mar 14, 2006 | 07:37 PM
57halfton's Avatar
Default RE: 65 door locks
can you lock them from the outside with the key?
from the inside buy turning the ****?
Gene
Old Mar 15, 2006 | 12:05 AM
maberry72's Avatar
NO, neither door will lock from inside or outside. This car sat for 2 decades and was run very little. I can't imagine the door locks had been used much if at all. I am very mechanically inclined but have learned from past endevors to not disassemble without prior knowledge of what's going on inside. Please help! I'm thinking of driving to a Power Tour stop in June.
Old Mar 15, 2006 | 07:51 PM
57halfton's Avatar
Well, let see, I can't image it could too many thing that could go wrong.
Do you have a chassis or body service manual that shows the Corvrtte body?
Do you have the special tool for removing the door handles, window cranks and lock ****? If not it's an inexpensive tool you should be able to get at most all parts stores or auto body supply store. Then there is a few screws on the bottom side of the door and some push thingies( can't think what you call them) on the front and rear of the door panel.
The first thing I would check is to see if the small rods are hooked to/ or missing that go from the locks to the lock mechenisam in the latch.
Would'nt think age and not being used would efect them, do the locks turn easy when you turn them with the key?
I'll take a look at my manual later and see what it says.
Gene
gracing76
Feb 26, 2007 08:19 PM
antjessash
Sep 9, 2006 08:08 PM
wloo64
Jul 5, 2006 02:27 PM
dok651
Apr 8, 2006 12:27 AM
VETTELOVER
Jul 31, 2005 11:44 PM
