1967 alternator issuue
Old Aug 6, 2011 | 07:28 PM
Bsuky's Avatar
Question 1967 alternator issuue
I am having problems with my 1967 435 alternator. I had it rebuilt and I was told that the core was burnt up. I installed the rebuilt, but is is running extremely hot. I changed the voltage regulator and it is still running too hot to to touch. The battery checks good and the output on the alternator is putting out approx. 14.5 volts and when I measure the current draw at idle it ranges from 9 to 11 amps. Is this too much? If so what should it be? The car has a ammeter gauge and is registering just pass center and increases when revving engine. Douse anyone have any ideas as to what the problem could be? Thanks
Can a battery with higher cranking power cause this problem?
Old Aug 7, 2011 | 05:00 PM
VetteBuilder1's Avatar
Check your ground on the voltage regulator as well as the ground wire that bolts to the back of the alternator. Bob
*026041*
Dec 3, 2006 04:36 AM
TealC4
Sep 26, 2006 12:59 AM
Fuzzy74
Jun 26, 2006 09:24 AM
Lee Willis
Mar 22, 2006 03:22 PM
itzfrank
Jan 10, 2006 09:15 PM
