Heat
Old May 7, 2006 | 12:18 PM
EC15's Avatar
Default Heat
I have a 1994 Corvette coupe. The problem is when the heat is on and the thermostat is set at max or any heat setting (car is up to tempature 195deg). I get intermitant heat out of the vents. First it will be cold then hot, cold then hot....any ideas to help me.
Old May 7, 2006 | 02:00 PM
Default RE: Heat
1st does your have automatic temp control. By that, I mean can you set the temp settings? If so, you might have programmer problems. Under the dash is a a/c programmer that opens and closes blend the door for your heater core to mix heated air with cold air from your evaporator. If your car does not have a programmer, the operation is controlled by the control head in the dash, which a simpler operation to replace. Before replaceing anything , to avoid any unnecessary expense, have someone with a scanner check for any body control codes first. [8D]
nautques4ever
Feb 10, 2007 10:13 PM
jetnoise
Oct 10, 2006 02:23 PM
faleure
Nov 26, 2005 03:46 PM
faleure
Oct 11, 2005 03:10 PM
BBPREPRO
Jun 29, 2005 07:31 PM
