First!
Old Jul 3, 2005 | 04:38 AM
heavymetals's Avatar
Default First!
Well I guess there aren't that many who post here!
Old Aug 9, 2005 | 05:11 PM
Default RE: First!
we are a fairly new site, but we are growing!! welcome aboard!!
Old Aug 9, 2005 | 05:28 PM
Default RE: First!
Yeah, it is a tad slow but all sites have to have a starting point and I know from experience with forums that they will grow once thw ord gets out. Welcome!
Old Aug 20, 2005 | 05:35 PM
Default RE: First!
Apparently not, but I will add my two-cents worth. I had a ZO6. Nice car.
I would love to correspond here with any one who is into heavy modifcations of the C5.
2002 Z06 - silver, from the factory with no options
Modifications:
General Motors Performance parts C5R block (4.25" bore) and
Crowler forged 4.00 inch stroker crank (427 cubic inches),
Crowler Forged rods
CP custom pistons with piston-centering of the rods, 10.1: compression ratio
Patriot III LS-6 heads with additonal porting, 2.08 inch intake valves
Crowler Stage III cam and roller lhydr. lifters
Jesel pro-series roller rockers, 1.7:1
Koches 1-7/8" headers and 3" H pipe
Super-size cats (yes, I run cats)
GHL cat-back exhaust
Underdrive main pulley
Procharger D1SC supercharger with dual intercoolers
and 3.4" pulley (gives 4.5 lbs of boost)
Dual core radiator with built-in oil cooler
FAST intake manifold with 90mm throttle body
re-programmed engine computer
harden output shafts in the rear end
Fiske forged billet wheels, 10x18 front, 12x18 rear
BFG G-Force 275 front, 345 Drag radials rear
Tigershark front end bodywork with increase radiator flow
Trunk bulkhead (custom)
Boost guage, exhaust pyrometer, and pre- and post intercooler intake temp guages
Trunk mounted battery kit (Lingenfelter)
540 ft lbs and 565 HP at the rear wheels with cats, 560 and 594 without
Old Aug 21, 2005 | 12:52 PM
Lorrin Philipson's Avatar
Default RE: First!
Wow, pretty nice car. I have an '01 with a Magnusen SC kit (non-intercooler) and short tube headers, Borla exhaust. dynos at 465 at the rear wheels.
Old Aug 21, 2005 | 05:53 PM
Default RE: First!
wow..sounds like you both have awesome cars!
Old Aug 22, 2005 | 11:08 AM
Default RE: First!
I like it a lot. I doubt I could ever get rid of it -- not that it would be easy to sell so modified.
The downside of all the mods is that the car is a bit to special to drive day to day. Its not that it won't behave and is not comfortable. It has all the original air, power options, etc., and the engine will lug in traffic at less than 1500 RPM fine. But it is a bit loud and the tires are very noisy, and just mashing down on the throttle to quickly in 1st or 2nd will snap the tires lose (even though they are 345s)- at any RPM. Plus I have only one place that can work on it (the speed shop that did all the work - the car has never been back to the dealer) so I tend to minimize the miles on it.
Still, on a nice day like this weekend, we took it out for a couple of hours cruising and its just grand:rule the street.
By the way, Lorrin, before putting in the 427 I had the stock engine with the Magnusen kit, too. Single best performance bargain I evern had. Ran flawlessly as a daily driver and the kit added 110 HP at the rear wheels and gobs of low end torque, and it had the best supercharger whine at full throttle I've ever had.
Default RE: First!
mraaron895
Feb 22, 2007 11:06 PM
splmagic1
Dec 24, 2006 09:01 PM
bmbndb
Oct 8, 2005 02:37 AM
Eagle223usa
May 30, 2005 01:30 PM
cbstbno70
May 13, 2005 01:22 AM
