Check Engine Light
Old Jul 13, 2005 | 12:31 AM
cmittag's Avatar
Default Check Engine Light
I have a
1982 Collector Edition Corvette. It runs great however when I turn the ignition off the check engine light comes on. Any ideas how to correct this?
Old Jan 18, 2007 | 11:17 AM
imjustsean's Avatar
Default RE: Check Engine Light
remove the light bulb
Old Jan 19, 2007 | 04:04 AM
Kobegotskillz's Avatar
ORIGINAL: imjustsean
Patient: Hey Doc, it hurts when I touch my arm right here.
Doc: Don't touch your arm right there.
Old Jan 19, 2007 | 05:23 AM
imjustsean's Avatar
i would tell you how to fix the light but i dont have one in my 77 so i dont know what the problem could be. i fixed my check engine light on my cavalier by removing it...i thought , but the light is still on and now my right turnsignal light dosnt work...so i just let it go
Old Jan 19, 2007 | 12:47 PM
Phill's Avatar
better yet lets cut the arm off!!
Old Jan 19, 2007 | 01:24 PM
wrwalke's Avatar
The check engine light comes on when you turn the car *off*? If the check engine light comes on while the car is running, I might worry a bit, but when it is off? No idea there. The check engine light is usually wired into a bunch of stuff, and tracking it down (without one of those nifty computers with "codes" to read) can be tough. The most common cause of check engine in modern cars... drumroll... the gas cap not screwed on tight.
bill.
Old Jan 20, 2007 | 07:45 AM
imjustsean's Avatar
or the o2 sensor. which if it is the problem save your cash and just torch the tip of it and screw it back in. i guarentee it works perfect. i used to do it on mustangs all the time
Old Jan 20, 2007 | 02:36 PM
Most of your auto parts stores will read out any codes that are set for free.
PAULKR
May 24, 2007 09:20 AM
CEILIA
Sep 20, 2005 07:40 PM
CEILIA
Aug 20, 2005 03:12 PM
rmd1960
Jul 31, 2005 11:13 AM
gerald452
Jul 21, 2005 08:24 PM
