Clunking noise
Old Jul 7, 2006 | 05:17 PM
mm4705's Avatar
Default Clunking noise
Hello,first timer here.Have a 00 manual tranny coupe.With car in gear, going slow,say 10-15 mph there is a clunking either from tranny or rear end.I hear when turning or forward.Any ideas ?
Old Jul 8, 2006 | 10:53 PM
Default RE: Clunking noise
The first thing I would do is jack up the car and take a good look underneath. Pound on the exhaust pipes to see if any are hitting body or suspension parts. Has either the tranny or rear end been worked on? Did you buy the car used?
Old Jul 10, 2006 | 11:05 AM
mm4705's Avatar
Bought car new, 38K mi.,no work only sched.service and with that only differential fluid was changed.No loose exhaust.Noise is not constant.Can only hear when radio is off.Forgot to add that when in reverse,going very slow,like parking,sometimes noise is a constant clunking sometimes.Car driven normal.By that I meen tranny & rear end not banged around hot rod'n.
Old Jul 10, 2006 | 05:22 PM
Does the frequency of the noise increase with increasing vehicle speed? I'm beginning to think the brakes, including the parking brakes, may need to be looked at if this is true.
Old Jul 10, 2006 | 05:30 PM
mm4705's Avatar
Sound does not increase,only heard at slow rpm's ,10 mph.Sometimes I can fell the clunk through the shifter.
POLOG91
Jun 4, 2009 05:30 AM
LT4Dave
Nov 11, 2007 10:13 PM
bobbyj
Sep 25, 2006 11:07 PM
bobbyj
Sep 22, 2005 12:45 AM
cr6sid9
Sep 14, 2005 12:57 AM
