engine heating problems
Old Jul 11, 2006 | 06:14 PM
johngarrison's Avatar
Default engine heating problems
I have a '65 Roadster with a 300 hp small block and auto transmission. In warm weather, like summertime, the engine temp runs 200 to 210 degrees. I can't make myself believe that this is design temp for the engine. I have a stock radiator that I have had out of the car and cleaned and boiled out. The water pump seems to be doing its thing and I have a new fan clutch. It has a 190 degree thermostat in it. Is there a coolant that will help with the engine temp? I want to keep the car stock so an aluminum radiator would be like a last resort. I would appreciate any info available. Thanks for the reply. John
Old Jul 12, 2006 | 06:33 PM
corvette king's Avatar
Default RE: engine heating problems
hi john,try redline water wetter,it will drop temp 20 deg,and try a 180 thermostat,that should help.and make shure your cap is in good shape,and you have no air in system.
[IMG]local://upfiles/1664/39A52A87EC2F40CB97244254C59AA5B6.jpg[/IMG]
[IMG]local://upfiles/1664/CFACFAE031514E969A472FA041E06B17.jpg[/IMG]
Old Jul 13, 2006 | 09:31 AM
In the 60's, they did not run that hot of thermostat. 200 degrees with a 190 degree thermostat is not uncommon. I would change to a 160 degree stat, make sure there is good airflow to your radiator and try the wetter chemical. [8D]
Old Jul 18, 2006 | 08:25 PM
Hey, Thanks for the comment. Can you tell me about the Wetter Fluid? Wherre can I find it? Thanks John
Old Jul 18, 2006 | 08:57 PM
Thanks for the reply. Where can I get the coolant? I really appreciate the information. John
rjensen
Jan 5, 2009 10:22 PM
bobalou
May 2, 2007 10:15 AM
toml14
Mar 12, 2007 08:59 PM
johngarrison
Aug 24, 2006 07:27 PM
johngarrison
Jul 11, 2006 07:08 PM
