1987 Bearing Size
Old Jul 16, 2006 | 07:36 PM
mikenann's Avatar
Default 1987 Bearing Size
I'm a New member with a little bearing trouble question. I have a 87 and want to put in new bearings in the engine. The rod bearings have a marking of .0005 OS on them and the Mains have a marking of .0006. What size of replacement bearings should I buy.
Tanks
Old Jul 22, 2006 | 12:32 AM
Tacky's Avatar
Default RE: 1987 Bearing Size
Probably your choices of bearing sizes will be limited to standard, 0.001" undersize, the 0.010 undersize.
I probably would Plasticgauge the bearings, then choose between standard and 0.001" undersize to keep the bearing clearance around 0.001 to 0.002"
Why do you want to replace the bearings?
Usually if the bearings are a problem, there are other problems.
74vett
Jul 9, 2007 02:11 PM
sleeprrr
Feb 15, 2007 11:57 PM
spooldup
Sep 25, 2006 12:14 PM
scotto
Jun 18, 2006 02:16 AM
jetmech09
May 18, 2006 02:05 AM
