check engine light 81 corvette
Old Jul 19, 2005 | 10:14 PM
gerald452's Avatar
Default check engine light 81 corvette
My check engine light is on i think because of my ecm is there anyway i can reset this light any information will be helpful
Old Jul 19, 2005 | 10:47 PM
buck's Avatar
Default RE: check engine light 81 corvette
You can take it to an Advance store and they will read the codes and tell you what is wrong. It's best to replace what is causing the error code or it will just return soon.
Old Jul 19, 2005 | 11:18 PM
gerald452's Avatar
Buck the car has no computer any other ideas
Old Jul 20, 2005 | 06:35 PM
DaveWJunior's Avatar
Is the light coming on as soon as you turn on the ignition? If you wait 30 seconds without starting the car does it go out?
I don't believe that there's any way to reset the ecm. It resets itself every time the car is turned off.
First thing I'd do is check the wiring to the oxygen sensors. If the ecm was fried, you'd know it because the car would be running a lot rougher.
Old Jul 20, 2005 | 11:29 PM
gerald452's Avatar
The light stays on no matter what you do but i will check the oxygen sensor wiring i appreciate the information thanks alot Jerry
Old Jul 21, 2005 | 08:24 PM
Default Gerald, what I would do.
depending on your state and how your car is inspected. I'd just pull the whole works out of there. Remove the bulb from the "check engine" socket, remove the air pump, EGR, etc. Give the car a little more power and doesn't seem to affect the performance at all. I've been running like this for years with no problems. Hey, with our 190 horsepower motors, we need to take everything we can!
PAULKR
May 24, 2007 09:20 AM
cmittag
Jan 20, 2007 02:36 PM
CEILIA
Sep 20, 2005 07:40 PM
CEILIA
Aug 20, 2005 03:12 PM
rmd1960
Jul 31, 2005 11:13 AM
