84 wont start
Old Jul 21, 2005 | 09:39 PM
84C4's Avatar
Default 84 wont start
i have an '84 with 46k that won't start. the fuel pump was replaced 5 yrs ago and i just replaced the fuel filter. it'll turn over for a while, almost start up with a sputter, then quickly die. any direction to point me in would be much appreciated
Old Jul 21, 2005 | 11:27 PM
buck's Avatar
Default RE: 84 wont start
Hey C4, You have to have 3 things to make an engine run Spark, fuel, and compression. I would start with pulling off a plug wire and ground it and see if it sparks. If it does then remove the fuel line and see if you have fuel pressure. and if it does then you need to check the compression. But from your thread it sounds like it's fuel related. If you have not changed the plugs in awhile, then that is affordable, I would try that.
Old Jul 23, 2005 | 11:31 PM
pilot1996's Avatar
Are you getting any codes?
Mac
corvetteofcobts
May 25, 2012 06:00 AM
art1298
Oct 6, 2011 05:46 PM
rjm
Nov 25, 2005 03:54 AM
hiax1971
Oct 9, 2005 08:45 PM
84C4
Sep 3, 2005 02:43 PM
