turn signals
Old Nov 5, 2006 | 03:43 PM
backdrat321's Avatar
Default turn signals
I have a 2001-c5 corvette and am having problems with my turn signals quiting and then starting again. Has anyone had any problems like this or do you know if there is a flasher unit that can be replaced? Thanks, Dave
Old Feb 9, 2008 | 08:57 PM
bj11670's Avatar
Default RE: turn signals
I believe there is a flasher relay that goes bad frequently on those models
Old Feb 10, 2008 | 12:46 PM
extanker's Avatar
cycle the haz.switch a few times
Old Feb 23, 2008 | 12:54 PM
KenHorse's Avatar
ORIGINAL: backdrat321
The Hazard switch (by the center air vents in the dash) is known to be a problem in C5s. The "normal" turn signals are routed through the hazard switch and when it goes, your turn signals become unreliable.
As extanker mentions, you can cycle the hazard switch a few times but the problem will become worse with time. The best fix is to replace the hazard switch (my 2002 Z06 had this problem too).
iwantfast
Sep 24, 2008 10:41 PM
cubbieman
Oct 10, 2007 09:49 PM
TNTs 84
Apr 26, 2007 03:23 AM
2001c5
Jul 28, 2006 01:44 PM
Teamhof
Jun 22, 2006 03:31 AM
