brake lights and turn signals
Old Sep 4, 2008 | 12:31 AM
iwantfast's Avatar
Default brake lights and turn signals
i have just finished painting the body and the jams and i am thinking that during all the wet sanding that i might have fouled up somthing.
I noticed that the reverse light's worked but not anymore, also the brake light's dont get brighter, and the turn signal just started screwing up. I think it might be in the turnsignal control unit in the steering.
Any help on this matter would be greatly appreciated.
Old Sep 4, 2008 | 01:15 PM
Rich G.'s Avatar
Default RE: brake lights and turn signals
Sounds like a ground problem to me.
Old Sep 4, 2008 | 06:41 PM
DeeVeeEight's Avatar
Banned
Yup, you lost the ground connection.
Old Sep 4, 2008 | 07:30 PM
iwantfast's Avatar
yeah i think all the wet sanding corroded the ground. Thanks i'll try tonite.
Old Sep 6, 2008 | 01:04 PM
Banned
ORIGINAL: iwantfast
Let us know what you found!
[sm=icon_cheers.gif]
Old Sep 23, 2008 | 10:47 PM
iwantfast's Avatar
Ok so i did the cleaning of the grounds and still nothing diff. I ground the locations with 36 sand paper. I heard that it might be in the column near turn signals? Anymore Ideas?????? Bueller???? Bueller???
Old Sep 23, 2008 | 11:53 PM
pg's Avatar
Hi iwantfast, not sure what year your car is but on my 74 with auto trans the back up lights are controled with the neutral safety switch which is under the center console. Pink wire brings power in and when the switch is closed (shifter in reverse) the power goes thru the green wire to light up the back up lights.
On a stick shift the switch is on the trany.
At the rear the yellow wire is for the left brake and left turn signal.
On the right a dark green is for the right brake and right turn signal.
Brown wire is for the tail and license plate light.
Checkand/or replace the turn signal flasher (under the right dash) and see if that fixes it.
Also chech the pigtails, where the bulbs go in and make sure the 1157 bulbs are installed properly. PG.
Old Sep 24, 2008 | 10:41 PM
iwantfast's Avatar
yeah i have a 79 and the right turn signal blinks but not on the dash and the left just stays on but the brake lichts dont get brighter and the reverse light's dont come on. I'll check the flasher fuse and the wiring but the car was sound untill i started wetsanding.
thanks i will let you know the outcome once again.
hey but the car has done a 180* turn looks very nice but has some bugs
gigabyte
Nov 11, 2008 02:44 PM
shevey
Sep 23, 2008 10:19 PM
TNTs 84
Apr 26, 2007 03:23 AM
2001c5
Jul 28, 2006 01:44 PM
Teamhof
Jun 22, 2006 03:31 AM
