Turn signals
Old Oct 6, 2007 | 01:58 AM
cubbieman's Avatar
Default Turn signals
Have a problem with my turn signals. When I first start the car they work fine. Start driving for about 10 minutes or until the car gets warm and they don't work. Turn my car off and back on and they work. Does anyone knows what could cause this.
thanks
Old Oct 6, 2007 | 07:44 AM
rshiver's Avatar
Default RE: Turn signals
Have you noticed if the brake lights are working when it happens?
Was wondering because the brake light circuit runs through the turn signal switch too.
Check and see and let us know.
Old Oct 9, 2007 | 07:04 AM
Junkman's Avatar
Try this. The next time they quit working, push the hazzard switch in and out a bunch of times. Then try the turn signals. If they start working, then your hazzrard switch needs to be replaced. This is a well documented issue.
Old Oct 10, 2007 | 08:49 PM
cubbieman's Avatar
I noticed that my hazards were a little tricky to use. This could be the problem. I'll check thanks
Old Oct 10, 2007 | 09:49 PM
fasttoys's Avatar
hazard switch i had where my turn signals would only flash couple times then stop
iwantfast
Sep 24, 2008 10:41 PM
backdrat321
Corvette C5 Z06
Feb 23, 2008 12:54 PM
TNTs 84
Apr 26, 2007 03:23 AM
2001c5
Jul 28, 2006 01:44 PM
Teamhof
Jun 22, 2006 03:31 AM
