Taking The A/C Compressor Offline
Old Nov 8, 2006 | 11:24 PM
All2kool's Avatar
Default Taking The A/C Compressor Offline
I'd like to have the A/C Compressor NOT come on with the Defroster as it is a little noisy. Will unplugging the Compressor have any ill effects on the car in general?
Old Nov 9, 2006 | 12:06 AM
Default RE: Taking The A/C Compressor Offline
It won't defrost the glas as well. The compressor running helps take moisture out of the air and that's what you want to defog glass. [8D]
Old Nov 9, 2006 | 11:47 AM
All2kool's Avatar
As for the windscreen staying clear, having just returned from a 1 hour drive I can honestly say that the windscreen stayed perfectly clear - even with the blower OFF. The side windows did have a very small amount of moisture on them but not to the point where vision was affected. The Hatch Window stayed clear as well, with the RWD off. My car spent the last 13 years in the desert, so mold developing in the system is very unlikely.
Bottom line, without the Compressor, the Defroster was still 95% effective.
Old Nov 10, 2006 | 08:33 PM
In a dry climate, should have no effect. But if it is humid and warm, it will be more difficult to work with out the compressor running.
Old Nov 10, 2006 | 09:55 PM
All2kool's Avatar
I do live in Oregon, where it rains quite often as it has been for the last 6-7 days. Although wet here, it isn't humid and warm. I'm not worried about mold at all.
Old Jun 8, 2026 | 03:00 PM
Kebo_57's Avatar
What I would suggest would be a great fix, but it would be a bit of a pain to do.... on my 93 there is an AC Request On signal that comes from the Vacuum Programmer module (mounted on the firewall right above the gas pedal) and goes to the clutch coil on the compressor. On my 93, if it goes low (basically 0.1VDC) that allows the coil on the compressor clutch to engage, thus bringing the compressor on line. If you pull that same signal high (to battery voltage) then the clutch will never be energized, thus preventing the compressor from working. If you can find that wire going to the clutch coil on the compressor, and rig up another wire that would be connected to a switch in the cabin to pull that signal high (to battery voltage basically), then you could override the compressor from inside the cabin. I have no idea how the 86 works as for as the AC controller goes, I just know how my 93 climate controller works. I am more or less assuming that the 86 is similar, but I could be all wrong too!!! Good luck!
chargedvette02
Oct 9, 2007 05:29 PM
scottr65
Sep 3, 2007 09:02 PM
White08vettE
Jun 5, 2007 05:10 PM
crausch
Jun 28, 2005 03:51 AM
