Corvette C6 Forum 2005+
Taking the cats of a c6???
Old Jun 4, 2007 | 07:45 PM
White08vettE's Avatar
Default Taking the cats of a c6???
any one make a pipe that replaces the pipes where thecats are??? if so please fill me in
Old Jun 4, 2007 | 09:56 PM
hippy's Avatar
Default RE: Taking the cats of a c6???
don't know, but you better find some good 02 sensor simulators to go with it. this advice is given for off road use only
Old Jun 5, 2007 | 05:10 PM
Yeah. Its called an off-road H pipe, and almost any aftermarket exhaust manufacturer offers one: Corsa, Borla, etc.
Realize that:
- it is illegal -- in states with visual inspections of emissions equipment you will likely get caught, in states without you probably won't
- on a stock LS engine is generally hurts performance slightly to remove the cats: the engine's cam and timing are designed to need a certian amount of backpressure.You will hear people say differently but not those who have actually measured the results on a dyno. On heavily modded cars removing the cats can bring you an additonal 25-30 HP (I run the largest size available on mine and removing them will add 25-30 RWHP, but I still run with the cats.
- if you remove the cats have the engine re-tuned (the ECM re-programmed), removal can result in the car throwing some codes sometimes or running a bit lean at times, both of which are not good.
ZR1clone
Mar 16, 2008 09:42 PM
White08vettE
Sep 18, 2007 08:53 PM
Str8upChevy
Dec 6, 2006 08:18 PM
skeeter103
Nov 7, 2006 09:01 PM
tankerpilot01
Sep 11, 2005 05:54 PM
