vin number
Old Aug 28, 2005 | 02:44 PM
1974corvetteowner's Avatar
Default vin number
i have a 1974 vette and i was woundering where the vin number was located
thanx 4 the help
Old Aug 29, 2005 | 10:45 AM
Default RE: vin number
The VIN should be right in the dash in front of the drivers seat. Should be able to see it from the outside looking into the windsheild. HOWEVER, on the older Vettes many of those fall off do to corrosion so yours might be gone. I am not sure where else the VIN is posted though. Also check the front of the engine block on the right side just below the head I think. But, that works IF that is the original engine.
Old Aug 29, 2005 | 06:19 PM
it should also be on the title, the insurance card, the owners card...
Old Aug 29, 2005 | 09:51 PM
red70vet's Avatar
There are several places that the serial number is placed but if you are asking this question I don't know if you will find them. It takes someone who has done it before or has a good working knowledge of what they are looking for.
1. Drivers side windshield pillar or driver's side dash at the edge of the windshield. If it is not there beware the car you have is illegal. Law requires it to be plainly visible.
2. Driver's side frame just above the rear wheel where the frame kicks up over the tires and rear trailing arms.
3. The last 6 digits will appear on the engine pad in front of the passenger side valve cover.
4 The last 6 digits of the serial number will appear on the tag on the passenger side of the transmission. the exact location depends on the transmission type.
5. On the title or registration, original bill of sale, warranty card(Potecto Plate)
Old Aug 29, 2005 | 10:51 PM
thanx but i found it it was on the drivers side A post and not on the dash where i would it should be
Old Aug 31, 2005 | 01:08 AM
red70vet's Avatar
Driver's side A post is the correct place for the vin on a 74 Vette.
Old Aug 31, 2005 | 01:38 AM
thanx thats where i found it
Old Dec 28, 2005 | 01:49 PM
reroe's Avatar
i am looking for a vin number also for my vette where exactly is the A post
Old Dec 28, 2005 | 01:51 PM
the A post is the post that the door is connected to and the windsheild also connectes to it the vin number should be right on it and u should be able to see it though the windsheild on the drivers side
husker
Apr 17, 2008 02:20 PM
fishdos
Nov 9, 2007 11:42 PM
CC/AT
Feb 24, 2007 09:14 PM
blueshark
Dec 21, 2006 02:27 AM
TealC4
Nov 15, 2006 12:06 AM
