fuel injector cleaner
Old Mar 8, 2007 | 03:59 AM
91c4guy's Avatar
Default fuel injector cleaner
I think I've been troubleshooting the wrong thing, as I think i have an injector problem now. I thought it was an electrical issue...but the car ran perfect...and after thinking about it....I did go kind of overboard with fuel injector cleaner, and according to a guy from a different forum he stated, "
With '85-88 Bosch injectors, do not use cleaning additives in the gas tank. Fuel-system cleaners are not recommended, by GM, because of the kinds of materials used in the fuel tank bladder, fuel O-rings, and fuel line hoses. If cleaning is required, use the GM specified procedure. On the other hand, Multec injectors, in the '89-01 models, do not need cleaning, and doing so could damage them."
This was taken from Ken's post, which was taken from Charles Probst book "Corvette Fuel Injection."
thing is I went crazy with the injector fluid. I used this cheap gumout injector cleaner from autozone it was like $5. That's when I started having starting issues, but I didn't think it would be the injector cleaner, since that was suppose to do good and clean the injectors. But any how, I finished the tank, filled her up again and added injector cleaner again. I started having starting issues...and at this time, it will not start any more. Cranks just won't start...and it's not the battery. So I assume it's most likely my injectors are damaged? Do they simply need cleaning or should they be replaced?[/align]
Old Mar 8, 2007 | 12:42 PM
Black86vette's Avatar
Default RE: fuel injector cleaner
I dont reccomend fuel cleaning soloutions but Redline and Chevron-Techron are pretty good. I woudlnt think they killed the inejctors? Possibly fuel pump or filter? Sock? Dont go out and buy new injectors unless you are positive that is the problem or youll be throwing down a couple hundred dollars down the drain...just my .02.
Old Mar 8, 2007 | 09:54 PM
Starting issues like you describe could be fuel pump related. Your car has a redundant voltage supply to the pump throught the fuel pump relay and through a oil pressure switch. Usually extended crank problems relate back to bad fuel pump relay and waiting for the car to build oil pressure while cranking to activate the oil pressure switch. If you can pull the catch basin from around your fuel neck, you can test for fuel pump voltage there to see if it is a supply problem.
Old Mar 12, 2007 | 07:43 AM
91c4guy's Avatar
Well I changed the ignition module and the fuel filter on it, and it seems to be running good now.
Old Mar 13, 2007 | 05:01 AM
imb1987's Avatar
I have an 89 and had the same problem, I used fuel injector cleaner and two weeks later my car would not start. Changed the fuel pump and inline and intank fuel filter and still nothing. So i took it to the shop and turns out the injectors were fryed! Good news was that they were going bad WAY before the cleaner and they said it wasn't the cleaner, bad news $1200.00!
Old Mar 13, 2007 | 12:28 PM
Yuck!!! 1200 bucks is steep for injectors. Pay for them and install them yourself.
Old Mar 14, 2007 | 10:13 AM
LeesVette's Avatar
ORIGINAL: Black86vette
I agree - thats an semi-easy Saturday install.
Old Mar 14, 2007 | 11:53 AM
91c4guy's Avatar
ORIGINAL: imb1987
Yah, you could of done that yourself I'm sure, but hey not everyone has the time. A set of injectors is $300. $900 seems expensive for labor but then again I don't know how long of a job that is, and labor rates are up the wazoo.your fuel injectors probably did get fried, as there was a GM service bulletin that specifically states fuel injector cleaner can damage fuel injectors for 87-91 vettes with the multec injectors. I think that happened to yours. I thought it happened to mine but thank goodness it was just a $30 ignition module or the $12 fuel filter. However, did you check to see if the injectors were fried before you took it to a shop? All you need is a multimeter and check the ohm readings, takes about 5 minutes to check all 8. I checked mine and they all tested good. Here is the service bulleting for those injectors though...if I were you I wouldn't use fuel injector cleaner any more.
Old Mar 14, 2007 | 04:08 PM
I bought a new set for 250.00 from Five 0 Motorsports. Make sure they are at least 22lb injectors. Do a search on Google. It is about a 4 hour job to replace injectors, you'll also need a intake plenum gasket set. You really need to do an injector balance test before just jumpimg in and replaceing them. The prob with that though is if you don't have an injector activating device to fire the injectors, it will be hard to do, since the injectors each have to be fired 50 times to measure correct pressure drop after cycling key each time to have a correct pressure baseline to start with. All injectors should be within a half pound pressure drop of each other. Bigger drop on any, fueling to much, smaller, to lean. [8D]
Old Mar 14, 2007 | 11:48 PM
Im no mechanic but I improvise. If I can find out how to do something I look it up on the internet or go to my Haynes manual......Has alot of info even though people put down on it. 15.00 dollars isnt that bad for what it does provide. If your goinng to do it yourself, might as well clean up everything under there, port the runners and plenum if you have a dremel. Clean out the throttle body, replace gaskets ect. [&:]
junior08
Apr 9, 2007 12:30 PM
redvet
Jan 3, 2007 09:35 AM
halbert
Nov 2, 2006 01:38 AM
arbasica
Sep 15, 2006 07:51 PM
ssa919
Jul 14, 2006 09:35 AM
