ac help
Old Mar 26, 2007 | 09:15 PM
fun4rx's Avatar
Default ac help
I have a 1989 coupe,with a bad Temperature Mode Door Actuator part #16025581.
might be called a temp. blender. I have it rigged up so in the summer the ac will
come on but it is full on. or I can shut it off for the colder months and it
is full hot. Does anyone know where to get this part or a fix around this, I'm told
the part is discontinued.
Old Mar 26, 2007 | 09:23 PM
motomaniac1988's Avatar
Default RE: ac help
I found this one online for 150.00
http://www.pacvette.com/store/store....at=9&sub=5
its like the tenth(ish) one from the top
hope it helps...
Old Mar 26, 2007 | 10:34 PM
Default RE: ac help
Any parts store that carries A/C Delco parts can probably get it for you if you got the GM number. [8D]
Old Apr 7, 2007 | 12:16 PM
fun4rx's Avatar
Default RE: ac help
Wow, thanks that is the part I've been looking for, I took my old one out and noticed the
plug in board looked dirty, I'm going to clean the leads and try it again, if that doesnt work
I'll order the replacement.
thanks, again
Old Apr 20, 2007 | 08:30 PM
fun4rx's Avatar
Default RE: ac help
Called them and placed order, but they e-mailed me and dont have any,said
they get 100 calls a week but can't fill many orders.
Old Apr 20, 2007 | 08:38 PM
fun4rx's Avatar
Default RE: ac help
the gm part number is 16025581 but my parts guy says he can't get one, tried some
used part guys, but no luck, this kind of worries me because you have no guaretee the
used part even works. Do you have a good link to AC Delco?
Old Apr 21, 2007 | 11:02 PM
Default RE: ac help
No link to Delco, but several part stores carry or can get Delco products, especially since you have the GM part number. Try Carquest, Bumper to Bumper, etc.
Old Apr 22, 2007 | 02:48 PM
Streak23's Avatar
Default RE: ac help
The problem with GM numbers is they tend to change them often. Call a dealership parts dept. and give them the number and see if it's been superceded with a new part number. Sometimes there are multiple part numbers for one part. Also ask them if they can provide you with the corresponding Delco number. It can be very tricky to cross some of the GM numbers to Delco, but once you have the Delco number to give the parts stores it can become much easier. When I managed an Advance Auto, we could get parts that weren't even listed in the computer and sometimes the part numbers would be in the system but wouldn't come up under the car's listings or in the books. Also I seem to remember some parts didn't even get assigned Delco numbers they just used the GM numbers.
spanky01
Jul 23, 2007 02:53 PM
mjrock62
Jun 8, 2007 07:07 AM
74vetguy
May 18, 2007 06:23 PM
aceosner1
May 16, 2006 09:23 AM
sixspeed042
Oct 10, 2005 02:00 PM
