Alarm Problems
Old Apr 21, 2007 | 04:11 AM
mraaron895's Avatar
Default Alarm Problems
I purchased my first corvette and have no idea how the alarm system works. I've been manually locking the doors because every time i electronicaly lock the doors and shut them, then unlock the door and open it, the alarm sounds. I'm always holding my breath as to wheather or not the alarm will sound. Its also quite embarassing.
Old Apr 21, 2007 | 11:06 PM
Default RE: Alarm Problems
1st, what year is your car? One of two things might be happening. There is a sensor ring that attaches to the door lock key tumbler that the factory alarm module looks at to see if you are using your key. Second, each door has a black plastic switch that activates your "Security" light on your dash. My money is with the tumbler sensor. Have to pull door panel to gain access to switch, not to fun of a job to do. [8D]
Old Apr 22, 2007 | 05:52 PM
mraaron895's Avatar
Its a 1986. I have been using a duplicate key without the pelet. Does this matter? The previous owner dissabled the VATS system as well. I think i'll go play with my alarm for awhile...
Old Apr 22, 2007 | 06:15 PM
mraaron895's Avatar
I tested my alarm and found that unlocking the passenger side door after i have armed the system will NOT cause the alarm to go off. Thank you very much mech259. What is the part called? Can i order it from midamerica?
Old Apr 22, 2007 | 08:13 PM
eggbutt's Avatar
my 85 does the same thing, passenger door only. I get bonus points from the wife, she thinks i am opening the door like a gentleman. not to cool when your with a dude!
Old Apr 24, 2007 | 10:48 PM
Crash's Avatar
I set off my alarm for the first time today , I had the hood open and tryied to push the car back without the key in the ignition so I pushed in the clutch and heaved backwards ( didn't really know I had an alarm) Beep Beep Beep unpluged the horns then proceeded to figure out how to turn the d@m thing off after about five min. of doing things I locked and unlocked the door with the key ,,,,Presto ,,, plugged in the horns again .My wife had a good laugh
Cheers
23outlaw
Corvette ZR1
Dec 17, 2010 12:02 PM
hombredog
May 23, 2006 02:10 AM
Superdzzz
May 6, 2006 12:39 PM
doc1
Aug 9, 2005 01:16 AM
Roadhack
Jun 10, 2005 03:11 PM
