"LOW COOLANT"
Old Oct 22, 2005 | 11:41 PM
tankerpilot01's Avatar
Default "LOW COOLANT"
All:
Just flushed out my coolant system and now I am getting a "Low Coolant" warning. It is full of fresh fluid and I'm wondering if anyone has any advice on how to get the sensor to "see" the new fluid. I'm assuming it is a sensor that is stuck or something? I've tried the tapping thing on the lid.....still getting it. Thanks for your help.
Kevin
Old Oct 23, 2005 | 04:14 AM
Default RE: "LOW COOLANT"
Did you open ALL of the air bleeds? I'm guessing you have one or more air pockets in your system.
Old Oct 23, 2005 | 11:59 AM
How do I do that? How many are there? I am unfamiliar. Thanks in advance!
Kevin
Old Oct 24, 2005 | 05:25 PM
The procedure is listed in the factory service manual, so you might want to pick a set up (see http://temp.corvetteforum.net/c5/ken...rtspage1.shtml). Many of the newer vehicles require that multiple bleeds are opened during the refill process. I normally have the dealership drain and refill my newer vehicles, primarily because I have a hard time getting rid of the old coolant.
Good luck.
Dave
Old Oct 24, 2005 | 10:49 PM
Cool, thanks. I will check it out. The Chevy dealer did the flush for me...and either didn't look or try to fix the low coolant warning. Thanks again for your help.
Kevin
Old Oct 25, 2005 | 01:27 AM
You're very welcome. I would take it back for them to bleed all the air out. It is inconvenient at times, but they need to do it right.
Good luck.
Dave
Old Oct 25, 2005 | 04:32 AM
Good point....I should just have them screw with it.
Old Oct 25, 2005 | 08:24 AM
The advice to get a set of servic e manuals is good, however. If you plan on doing much of anything yourself other than parking and looking at it they will pay off. I bought my set from Ecklers about 3 years ago for about $300. Three big volumes (about 8 inches thick altogether). They have come in handy several dozen times I never would have anticipated.
C4land
Feb 3, 2008 10:51 AM
GrampsC4
Oct 15, 2007 11:56 AM
GrampsC4
Sep 19, 2006 09:48 AM
